Displays the RPF for a specified multicast source.
| ipaddress | Specifies an IPv4 address. |
| ipv6address | Specifies an IPv6 address. |
| rpf | Selects the RPF for the specified multicast source. |
| vr_name | Specifies the VR or VRF for which to display the route. |
vr_name is the VR of the current CLI context.
None.
The following example displays the RPF lookup for a multicast source through VR-Default:
rtlookup 2001db8::ef80:2525:1023:5213 rpf vr vr-default
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
